give us some gas the car would just shut off?
96,717 MILES • 3.1L • V6 • 2WD • AUTOMATIC
MELOMAN7
The last week or so my car hasn’t start up and then when I do get it running, I would give it a little gas and then it would sound like it wanted to die out and then we’ll keep running then when I would put it in gear and give us some gas the car would just shut off. I changed the fuel pump, ignition coils, wires, spark plugs crankshaft sensor. Do you think my ignition control module needs to be replaced?
Nov 29, 2025 at 5:52 AM
  • 55,686 POSTS
This can be caused by many things such as a bad throttle body, accelerator pedal sensor or bad MAF sensor, the best way forward is to runt he codes to see which ones are stored. Here is a guide to help us see what is going on.
It can even be the engine has jumped time. Please upload a short video in your response of the engine cranking over so I can tell if the engine is still good :) Please go over this guide and get back to us.
Dec 1, 2025 at 1:49 AM
