Engine will not turn over?
279,261 MILES • 4 CYL • 2WD • MANUAL
CHRISTINA2323
I turn the key and it will click as long as the clutch is pushed in and out wont turn over and the battery is not drained out.
Feb 21, 2021 at 11:15 PM
  • 110,248 POSTS
If the battery is charged, then either we have a weak connection or the starter is bad. First, check to make sure the battery terminals are clean and tight, free of corrosion. Here is a link you may find helpful:
If that is good, confirm the click is coming from the starter. If it is, then replace the starter. I say replace it because if it is getting power and not turning, it's bad or the engine is locked up You didn't mention any issues with the engine, so I am assuming the starter is the issue.
Here is a link that shows in general how to replace the starter:
IF you want to confirm the starter is getting power, here is a link that will help you with doing that:
__________________________________________
Here are the directions specific to your vehicle for a starter replacement:
1995 Toyota Camry Sedan 4-Door L4-132 2164cc 2.2L DOHC (5S-FE)
Procedures
Vehicle Starting and Charging Starting System Starter Motor Service and Repair Procedures
PROCEDURES
1. On models with coded audio anti-theft systems, refer to Technician Safety Information for code procedures.
2. Disconnect battery ground cable.
3. On models equipped with cruise control, remove battery and cruise control actuator.
4. Disconnect electrical connectors from starter motor.
5. Remove starter motor attaching bolts, heat shield (if equipped), then the starter motor.
6. Reverse procedure to install.
____________________________________________
I hope this helps Let me know if you have other questions.
Take care and God Bless,
Feb 25, 2021 at 8:07 AM
