Gray smoke coming out and an idle rpm problem
169,000 MILES • 4 CYL • 2WD • AUTOMATIC
VINCENT15
There’s gray smoke coming out and an idle rpm problem and it turned off and won’t crank.
Jun 14, 2019 at 5:22 AM
Hi Vincent,
Sounds like you have a fuel issue. The gray smoke is excess fuel being burned. I would suggest with starting with get the codes from the computers. I am sure there are some due to the rough idle and now the no start.
We need the codes because there is not a direct correlation between the poor running condition and a no crank situation. If it cranked and just did not start, that would be different but a no crank is electrical (normally) and just a rich running engine does not normally cause that.
https://www.2carpros.com/articles/engine-black-smoke
Let me know if you can get the codes and we can go from there. Thanks
Jun 14, 2019 at 5:40 AM
