I ripped the ring wire that is around the key?
200,000 MILES • 2.5L • 4 CYL • AUTOMATIC
300CHRYSLER
  • 41 POSTS
So I lost my key to my car listed above. I tried to hot wire my car by me doing that I broke some parts to my car. I ripped the ring wire that’s around the key location and then I opened up the ignition switch that’s behind the key location, but I closed it right away. I was able to make it crank but no fuel is been let out antitheft system. So the next day I called a lock smith and made a new key but still won’t turn over. Can the parts that I messed up be the reason why it won’t turn on? The first pik I ripped it out it had wire around it and the 2 pik I opened where it’s pointing but I closed it right away.
Jul 31, 2025 at 4:48 AM
  • 55,711 POSTS
Can I ask if the security light is flashing? If so, the alarm is enabled. I would do a hard system reboot which this guide can show you how:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Next, if you opened the ignition switch it could have messed up the contact plate so now the switch will not work anymore.
On the first image which is the NATS Antenna Amplifier that has to be in place so it can read the new key, which I assume was coded by the locksmith? Check out the images (below). Please let us know what happens.
Jul 31, 2025 at 6:01 AM
300CHRYSLER
  • 41 POSTS
Yes the alarm is blinking red but before the key thing I would drive n the light would stay blinking all the time if I put the car on acc the light stops blinking n yes I did mess the ignition thing I tried what u told me n still it will crank but won’t start
Aug 1, 2025 at 8:32 AM
  • 55,711 POSTS
This means the alarm system is enabled, did you try the hard system reboot? If so lets do a CAN scan to see what codes are stored, this video will show you how.
https://youtu.be/u-4syLc-ifQ
Please go over this guide and get back to us.
Aug 1, 2025 at 10:12 AM
300CHRYSLER
  • 41 POSTS
So it didn’t turn on but it gave me a code p0603
Aug 1, 2025 at 2:07 PM
  • 55,711 POSTS
This just means the battery was disconnected recently, we need a CAN scan because it will give you the code for the security system
P0603 - ECM/PCM Keep Alive Memory (KAM) Error
A CAN scan is different than a regular engine scan. Is the NATS antenna amp in good working order?
Aug 2, 2025 at 2:15 AM
300CHRYSLER
  • 41 POSTS
No that is not working at all
Aug 2, 2025 at 4:53 AM
  • 55,711 POSTS
What is the OBD2 port or the NATS antenna amp? The amp (ring around the key) must be working for the security system to disable.
Aug 3, 2025 at 4:17 AM
300CHRYSLER
  • 41 POSTS
Thank you guys my car is running again now with a diff problem ima load a video so maybe you guys can help me figure out the problem so when I’m driveling it feels like my rotors calipers something on tires is gona break my husband lifted the car to see but what do you guys see please help
Aug 12, 2025 at 10:48 AM
  • 55,711 POSTS
We can help, but I am sorry we only handle one problem per thread, can I ask what fixed the last problem? Please post your new question here, you must be logged in.
Cheers, Ken
Aug 13, 2025 at 3:19 AM
