My car wont start at all, and no lights comes on
20,000 MILES • AUTOMATIC
KOUBEAR
  • 43 POSTS
My car wont start at all, and no lights comes on not even my dashboard comes on.
Aug 29, 2021 at 5:58 PM
SQM
  • 6,383 POSTS
Just so we cover all the possibility.
Have you tried to jump start the car?
It could just be a dead battery. As you do not have any lights coming on the dashboard, that typically points to a bad battery.
If you are able to jump start it and it runs fine that it is the battery that is at fault.
Here are some helpful articles:
https://www.2carpros.com/articles/how-a-car-battery-works
https://www.2carpros.com/articles/how-to-jump-start-car-battery-using-jumper-cables
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Let me know what you find out.
Aug 30, 2021 at 2:40 AM
KOUBEAR
  • 43 POSTS
Hello
no I have not tried to jump start my car yet.
Sep 4, 2021 at 3:29 AM
SQM
  • 6,383 POSTS
The symptoms you mentioned sounds like a dead battery.
If the battery is bad, you will be able to jump start it.
Sep 4, 2021 at 3:35 AM
KOUBEAR
  • 43 POSTS
I tested the battery using a multimeter and it was at 5.6 but that's only because I haven't drove or started it for 2 weeks maybe more. I'm starting to think it's one of my electrical components.
Sep 4, 2021 at 6:03 AM
KOUBEAR
  • 43 POSTS
Because I can't turn on my headlight or none of my electrical components seems to be working at all. I use my spare keys and it seems weak then not working. Ugh.
Sep 4, 2021 at 6:06 AM
SQM
  • 6,383 POSTS
You could have excessive amount of parasitic draw (current drain) on the battery.
Every circuit will have some amount of draw but it can become excessive due to a issue with a electrical component.
Here is a guide of how to find the parasitic draw:
https://youtu.be/z5F7WpgjaRs
https://www.2carpros.com/articles/car-battery-dead-overnight
Let me know if you have any questions.
Thanks.
Sep 4, 2021 at 1:37 PM
KOUBEAR
  • 43 POSTS
Hey, so when I jump started the car it works fine. everything was working properly, but the next day when I tried to start it again everything shut off?
Sep 25, 2021 at 7:24 AM
KOUBEAR
  • 43 POSTS
Is that a sign I have a bad battery? Alternator? Or parasitic drain or a bad ground wire somewhere?
Sep 25, 2021 at 7:25 AM
SQM
  • 6,383 POSTS
It can be that you have a bad battery. Parasitic drain is another possibility.
But it does not seem to be the alternator. If it was the alternator then the car would not stay running after the jump start. Remember a car will run with a jump start just fine, even with a bad battery. It's just you won't be able to restart it after shut off.
I think next best step would be to get the battery tested. You can do a load test on your own or take it to your local auto parts store and they can use their machine to do the load test (more accurate).
Follow this guideline to do load test on your own:
Let me know what you find.
Sep 25, 2021 at 8:48 AM
KOUBEAR
  • 43 POSTS
Hey, I tried to jumpstart my car again and my light and horn went on (flashing)? Please help.
Oct 1, 2021 at 7:07 AM
SQM
  • 6,383 POSTS
It sounds like the anti theft got triggered. Disconnect the negative battery cable and wait for about a minute. That should reset the system.
Oct 1, 2021 at 7:14 AM
KOUBEAR
  • 43 POSTS
Oh, but I read some post and some people say that using the key should stop it?
Oct 1, 2021 at 7:17 AM
KOUBEAR
  • 43 POSTS
What would happen if I did reset my system?
Oct 1, 2021 at 7:20 AM
SQM
  • 6,383 POSTS
Yes, you can stop it with the key. That is the proffered way. Only time you want to unplug the battery if your key fob is missing or not functional.
Oct 1, 2021 at 7:22 AM
KOUBEAR
  • 43 POSTS
All right. So, I just have to lock it and unlock it and it should be fine? Can I use the key button's function, or do I have to insert the key in the door?
Oct 1, 2021 at 7:26 AM
KOUBEAR
  • 43 POSTS
Was checking out my battery and noticed this. I don't know if it is new or it was always there.
Oct 1, 2021 at 8:40 AM
SQM
  • 6,383 POSTS
The battery cable is normal. I don't know why Toyota does not put an insulation on the wire at that connector.
Any time the alarm goes off you should be able to turn it off by pressing the lock and unlock button on the key fob. If that does not work, then you will have to put the key in the ignition and turn to on position.
Oct 1, 2021 at 2:30 PM
KOUBEAR
  • 43 POSTS
Key fob button didn't work and didn't try turning on ignition didn't want to ruin it anymore. There was some electric spark or something when connecting the jumper cable (I forgot if it was the positive or negative cable that did it).
Oct 2, 2021 at 3:25 AM
SQM
  • 6,383 POSTS
Got it. So as of now, what are you experiencing? Still not start?
Is your security light staying on?
Or were you able to jump start it?
Oct 3, 2021 at 3:31 AM
KOUBEAR
  • 43 POSTS
Hey, changed my battery and now it works fine now. (:
Oct 15, 2021 at 5:03 AM
SQM
  • 6,383 POSTS
That is good news. Let me know if something comes up.
Oct 15, 2021 at 5:27 AM
KOUBEAR
  • 43 POSTS
I want to install a dashcam for the front and back but my only concern is if it will affect the warranty (I have it for almost 3 years) the dashcam requires me to swap out the interior rear-view panel with a new one?
Oct 15, 2021 at 5:31 AM
KOUBEAR
  • 43 POSTS
Ever since my accident I been wanting too. Would you consider that a modification?
Oct 15, 2021 at 5:35 AM
KOUBEAR
  • 43 POSTS
The camera I want to install.
Oct 15, 2021 at 5:36 AM
SQM
  • 6,383 POSTS
As long this is a plug and play and you are not splicing wiring, this should not affect warranty.
Oct 15, 2021 at 5:43 AM
KOUBEAR
  • 43 POSTS
All right. Thanks.
Oct 15, 2021 at 5:53 AM
SQM
  • 6,383 POSTS
You are welcome.
Oct 15, 2021 at 6:37 AM
KOUBEAR
  • 43 POSTS
I notice that my car gas cap cover isn't working when I push on the button? Is there a fuse or repay for it ?
Oct 15, 2021 at 7:42 AM
SQM
  • 6,383 POSTS
Since this is a new issue, can you please open a new thread? As it can help anyone who might have the same issue.
This will also put it in front of all the experts.
Just got to this link:
Oct 16, 2021 at 2:07 AM
