Broken key in the ignition, how do I get the key out or even turn my ignition to accessory to get the ignition cylinder changed?
200,000 MILES • 2.2L • 4 CYL • 4WD • AUTOMATIC
KAITLYNNB22
Someone broke into my car and tried to steal it. I have a tip of a key stuck in my ignition turned over to "on".
Jul 18, 2022 at 10:42 AM
  • 110,244 POSTS
Wow, that is a tough one. In the past, I've been able to get broken keys out with a magnet or even a strong vacuum that is directed at the broken key. However, I suspect they wedged the key into place.
At this point, you will likely need to drill out the tumbler where the key goes to remove the broken key. Another thought is a locksmith may be able to help. They have tools to access the tumbler.
Try contacting one to see their thoughts. If they say no, I suspect you will need to drill it out.
Let me know if I can help.
joe
Jul 18, 2022 at 3:24 PM
