Ignition
200,000 MILES • 6.6L • V8 • 4WD • AUTOMATIC
KEITHDEVILSLAKE
I turn it over and sometimes it will not get electrical connection.
Jul 9, 2018 at 3:04 PM
  • 110,248 POSTS
Since it only happens at times, it could be a bad connection at the battery. Take a look through this link and let me know if it helps or your thoughts.
Jul 12, 2018 at 12:49 PM
KEITHDEVILSLAKE
Thanks for responding Joe, the connection at the battery is all good. I am thinking it is the shifting rod in the column that is broke or just somehow got unhooked. I did replace ignition switch on the lower part of the steering wheel (column).The switch was not the problem, so I am thinking it is the key part of the ignition that is bad or like I said that rod that runs along the steering column.
Jul 21, 2018 at 8:58 PM
  • 55,721 POSTS
It sounds like a starter or the neutral safety switch. Does the truck turn over if you manually work the switch?
Test for power going to from the ignition switch. Here is a guide:
Cheers, Ken
Jul 25, 2018 at 8:38 AM
