Ignition?
230,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
ROOT1UP
Starts right up and shuts off, if the key leaves the crank position. Will idle and run only while being cranked over.
Mar 5, 2023 at 8:27 AM
  • 55,711 POSTS
It sounds like the ignition switch is bad, but I would check all fuses as well. Here is a guide to help and if the fuses are okay, I would change the ignition switch out. Check out the images below.
Let me know how it goes. Check out the images (below). Please let us know what happens.
Mar 6, 2023 at 2:12 AM
