Will not stay running
130,000 MILES • 1.6L • 2WD • AUTOMATIC
FARR2007
  • 244 POSTS
Car will crank over and fire up but stalls out right away. I just put a new fuel pump in. I can crank it and crank it, but it also has no throttle response. I think the ignition is cutting the fuel pump out.
Jun 6, 2022 at 8:06 AM
  • 110,248 POSTS
This could be a fuel-related issue or ignition-related. By chance, have you scanned the computer to retrieve diagnostic trouble codes? Here is a video showing how it's done:
https://youtu.be/b2IJGfImVvw
Also, I've seen where the crankshaft position sensor can cause this. Take a look through this link and let me know if it seems to mirror what you experience:
Also, pay attention to see if the tachometer is moving when you crank the engine.
Jun 6, 2022 at 4:14 PM
FARR2007
  • 244 POSTS
I put a new crank sensor in the car, but the symptoms stayed the same. Is it possible the knock sensor is bad? Or could I have gotten a faulty crank sensor from Oreilly's, also is there a way to manually put gas in the engine to get it to fire and run? also, could timing be off or fuel/air ratio and if so, how can I fix this problem?
Jun 10, 2022 at 7:00 PM
FARR2007
  • 244 POSTS
Also, this is what lights I have on dash , nit shown Is flashing light that is a yellow a meaning it looks like a letter a with a circle around it and it flashes when attempting to start car.
Jun 10, 2022 at 7:18 PM
FARR2007
  • 244 POSTS
This is what lights I have on dash, not shown Is flashing light that is a yellow a meaning it looks like a letter a with a circle around it and it flashes when attempting to start car.
  • 110,248 POSTS
Any of the things you mentioned could cause a no-start. As far as the crank sensor, yes, it's possible to get a bad one. Have you checked to see if it is getting spark? If the sensor is bad, you will lose spark to the plugs. Here is a link that shows how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Since this is a 2013, the best thing to do would be to scan the can-bus. CAN stands for controller area network. Basically, all the different modules/computers are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them. Here is a link that shows how it is done:
Also, I copied one of your pics and circled what I believe you are referring to. Take a look and let me know if I'm correct. If I am, that is a tire pressure indicator lamp.
See pic below.
Jun 11, 2022 at 12:18 PM
FARR2007
  • 244 POSTS
Can you give me a detailed description of where all the sensors are located?
Jun 11, 2022 at 9:41 PM
  • 110,248 POSTS
I would be happy to. If you are referring to the tire pressure sensors, each wheel has one. I attached a pic below showing one.
If there are others you need, let me know.
See pic below.
Jun 12, 2022 at 12:51 PM
FARR2007
  • 244 POSTS
What does the tachometer have to do with it not starting?
Jun 20, 2022 at 10:26 PM
  • 110,248 POSTS
If the tachometer doesn't move when you are cranking the engine, there is a good chance there is no RPM signal from the crankshaft position sensor which is required for it to run. I realize you replaced it, but there could be a wiring issue.
By chance, could you record it cranking and upload it for me to hear?
Jun 21, 2022 at 6:27 AM
