Ignition key is stuck?
150,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
EAZYEP
Key won't turn back to cut car off key is stuck.
Feb 1, 2025 at 10:22 PM
  • 55,711 POSTS
This happens when the ignition lock tumbler needs to be replaced. here is how the job is done to fix the problem. This guide can help as well:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Feb 2, 2025 at 2:59 AM
