Ignition
250,000 MILES • AUTOMATIC
SEAGRAVES33
When I put the key in the ignition, the interior light come on and it chimes if the door is still open. However, the key will not turn at all. I have not had a problem like this out of it before. The steering wheel is unlocked, the gear shift is in park, the wheels are straight. Is there another quick fix?
Aug 12, 2017 at 9:38 PM
  • 55,746 POSTS
It sound like the tumbler has gone bad and needs to be replaced, Here are some diagrams that will help you get the problem fixed.
You will need to get the dealer set the ignition key up.
Cheers, Ken
Aug 14, 2017 at 12:12 PM
