Turn the truck on and the starter continues to crank
235,000 MILES • 4.0L • V6 • 4WD • MANUAL
SHAGGY1911
I turn the truck on and the starter continues to crank, even if I turn the key off. I'm pretty sure it's the key ignition cylinder sticking but have to pull steering wheel to replace it, so I figured I'd ask the pro's first. Thank you for your time. :)
Mar 11, 2019 at 12:21 AM
  • 55,710 POSTS
This happens when the battery gets weak not having enough voltage to retract the solenoid. This guide will help confirm the issue:
Mar 14, 2019 at 5:43 AM
SHAGGY1911
it was my key ignition cylinder or for now anyways, thank you for your help though. :)
Mar 16, 2019 at 1:28 AM
  • 55,710 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Mar 17, 2019 at 8:43 AM
