Code p0263 Igniter fault
229,299 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
TERRY STANFORTH
Engine fault code p0263. Changed the MAF already.
Feb 21, 2021 at 12:44 AM
DAVEH429
  • 41 POSTS
Hello.
Code P0263 for Hyundai is triggered when the PowerTrain Control Module (PCM) detects that the acceleration rate of the crankshaft for Cylinder #1 was less than a calibrated amount. During normal conditions the PCM turns the fuel Injectors "on" and "off" in the Fuel Injection System.
Symptoms
Possible symptoms of OBD code P0263 Hyundai
– Engine Light ON (or Service Engine Soon Warning Light) – Engine Misfire – Engine Run Rough – Low MPG
Causes
Possible causes of OBD code P0263 Hyundai
– Fuel Injector #1 – Faulty or Corroded Fuel Injector #1 Connector – Plugged/blocked #1 Fuel Injector – Dirty #1 Fuel Injector
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Hope this helps, please keep us up to date on your repairs.
Thanks,
Dave H
Feb 21, 2021 at 5:07 AM
