ign key locked but will turn nothing happens
52,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
LYNN1107
ignition key will turn nothing will engage, key wont come out it is zero degree out side battery yesterday worked fine. also need answered how to remove battery case to charged battery. every thing asked like a dead battery I haven't checked the battery yet. need to know how to remove plastic cover from battery box
Jan 27, 2014 at 1:37 AM
  • 110,248 POSTS
I'm not sure what black cover you are referring to. Is it a plastic box that covers the battery with the terminals jutting out from the top?
Jan 27, 2014 at 1:48 AM
LYNN1107
yes it is the plastic box that covers the battery
Jan 27, 2014 at 2:03 AM
  • 110,248 POSTS
Once you remove the battery terminals, it should slide off.
Jan 27, 2014 at 2:53 AM
LYNN1107
it the top plastic lid that covers the battery that has to be removed
Jan 27, 2014 at 3:26 AM
  • 110,248 POSTS
To the best of my knowledge, yes. However, it is hard to say without seeing it.
Jan 29, 2014 at 12:26 AM
