IGN 0 fuse in interior left panel keeps blowing?
315,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
DAFUNKYBEAN
Fuse blows when ignition put into start to crank engine. It is fine when just in run or accessory position. Right side of fuse indicates power when tested w/light tester, but left side does not. I have replaced the ignition switch. IGN C fuse in under hood fuse panel good and lights up when tested. I am having trouble tracing where short might be located. I read the wiring diagram to be that the short would be located between IGN C fuse and IGN 0 fuse. With the ignition switch having been replaced, this leaves the direct line from the under hood panel to the ignition switch. Is this correct? There is a yellow wire from the under hood fuse panel that runs through the ignition switch and to the IGN 0 fuse that does not light when tested. How can I tell which wire this is and might it be the culprit?
Apr 12, 2015 at 2:30 PM
HMAC300
  • 48,601 POSTS
see the two pics one goes to powertrain module under hood and other to trans. it could be at junction block as well. try to get a circuit breaker to temp install while checking it as well as a compass to run along wiring, if wiring is screwed up it will drive compass crazy. it's a pink wire see pics.
Apr 13, 2015 at 12:36 AM
DAFUNKYBEAN
That helps a lot. I'll try to check it later today and let you know. Thanks!
Apr 13, 2015 at 1:29 AM
DAFUNKYBEAN
It turned out to be a wire for the tow package. thanks for the advise, put me toward the right path.
Apr 13, 2015 at 9:44 AM
JOHN ADAMS2
My truck lost all dash gauges and lights last night and the transmission it stuck in I think third gear. when I put new fuse in the Ing 0 it pops right away. did your truck do this?
Mar 8, 2021 at 8:06 AM
  • 110,248 POSTS
If the fuse is blowing as soon as it's installed, there is a dead short at some point. Check for shorts at the box and near it. If you do it in the dark, you may see a spark indicating the short.
Let me know what you find.
Mar 10, 2021 at 9:26 AM
SONNY26
can't find the IGN O fuse, 2000 Astro
Sep 10, 2023 at 5:40 AM
  • 55,616 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Sep 11, 2023 at 4:44 AM
