iginition key will not turn all the way back when turning it off.
187,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
NELSOND1
I have a 2000 GMC Jimmy with 187k miles. Having a problem with the ignition getting stuck when trying to turn it off. If you turn the steering wheel and jiggle the shifter and hit the brakes it will sometimes release and turn all the way off. It feels like the tumblers are not lining up so it can't turn back freely. Will oiling it help? Any other ideas?
Thanks,
Dan
Sep 19, 2014 at 11:38 AM
WRENCHTECH
  • 20,758 POSTS
No, it has a lockout so it can't be locked when not in Park. Some use a cable and some use an electronic solenoid that goes bad. It's going to require some dis-assembly and investigation to determine the problem.
Sep 19, 2014 at 10:38 PM
