Used car advice?
2006 HONDA CRV
230,000 MILES
AARONN
  • 125 POSTS
Assuming both are clean titles with no issues mostly. I am leaning towards the Honda- especially since I want a vehicle with minimal issues.
2001 Chevy Blazer
156k miles
Or
2006 Honda CRV
230k miles
Both are similarly priced at $2k- before price negotiations
Feb 12, 2025 at 2:05 AM
CARDOCTOR74
  • 62 POSTS
Hi welcome, worked on Honda many years as for the right choice Honda would be it. If it was dealer maintained, I would just make sure the a/c works as there were compressor issues with this year and as always check for any codes and take for a long road test if possible, to rule out any drive-ability issues. That year has a timing chain so make sure there are no rattles behind the timing cover as well. I always recommend a used car check at a shop will usually charge $100.00 or so but it is well worth it to see if there are any issues or leaks.
Very glad to help.
https://www.2carpros.com
If you found this helpful, I would not object to a tip at the Venmo link below lol. I’m here if you need me.
https://venmo.com/u/hondaguygold
Feb 12, 2025 at 2:40 AM
AARONN
  • 125 POSTS
The chevy has 74k less miles if that means anything?
Feb 12, 2025 at 2:42 AM
CARDOCTOR74
  • 62 POSTS
Those have notorious engine and transmission issues that are not as reliable.
Feb 12, 2025 at 2:50 AM
CARDOCTOR74
  • 62 POSTS
Also check the frame for rot and rust.
