If disconnect your SRS, can you still drive it
2,007,422 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
ELLEN LEFLORE
Whenever I use the headlights, or radio my battery drains, then my SRS light comes on. Then the car tries to shut off. It starts puttering. I know there is a connection problem somewhere because when I hit a bump sometimes the power drains but sometimes if I hit another bump. The power comes on with a full charge. Once the power comes on again with full charge the vehicle runs perfect and the SRS light goes off. I did get into a little finder bender not too long ago by the headlights. I am thinking maybe that could have knocked some wires loose.
Aug 17, 2017 at 11:27 AM
  • 55,709 POSTS
Hi Ellen,
That was what I was going to say. Up where the fender bender occurred that is a ground wire that sounds like it is loose. You can probably jack up the front end to find it.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Cheers, Ken
Aug 18, 2017 at 6:47 AM
STEVE W.
  • 15,409 POSTS
Loose wires or a pinched wire in the harness. Shouldn't be too hard to find, just look for areas where the wiring runs and is squeezed. I would do it ASAP, if the wires get cut you may end up with more problems.
Aug 18, 2017 at 3:22 PM
