Idling up and down from 1200 to 2000 rpm
186,000 MILES • 3.0L • V6 • 2WD • MANUAL
TONIO SELLERS
  • 7 POSTS
Car just idles up and down when engine is warm.
Oct 12, 2018 at 7:46 AM
  • 110,248 POSTS
Based on your description, it sounds like there is a problem with the IACV-AAC valve. This system automatically controls engine idle speed to a specified level. Idle speed is controlled through fine adjustment of the amount of air which by-passes the throttle valve via IACV-AAC valve. The IACV-AAC valve changes the opening of the air by-pass passage to control the amount of auxiliary air.
Now before just replacing the valve, check to make sure there is no carbon build up on the throttle plate. If it appears clean and closing properly, then remove the IACV-AAC valve and inspect it for carbon or any dirt.
I have attached a picture of the component and location for you. If the valve is to be replaced, there is a relearn process that requires Consult II scanner or equal. Here is the relearn process with a manual transmission. Starting with picture 2, the remaining pictures correlate with these directions.
______________________________________
DESCRIPTION
"Idle Air Volume Learning" is an operation to learn the idle air volume that keeps each engine within the specific range. It must be performed under any of the following conditions:
- Each time IACV-AAC valve, throttle body or ECM is replaced.
- Idle speed or ignition timing is out of specification.
PRE-CONDITIONING
Before performing "Idle Air Volume Learning", make sure that all of
the following conditions are satisfied.
Learning will be cancelled if any of the following conditions are
missed for even a moment.
- Battery voltage: More than 12.9 V (At idle)
- Engine coolant temperature: 70 - 99° C (158 - 210° F)
- PNP switch: ON
- Electric load switch: OFF
(Air conditioner, headlamp, rear window defogger)
On vehicles equipped with daytime running light Systems, set lighting switch to the 1st position to light only small lamps.
- Cooling fan motor: Not operating
- Steering wheel: Neutral (Straight-ahead position)
- Vehicle speed: Stopped
OPERATION PROCEDURE
With CONSULT-II
1. Start engine and warm it up to normal operating temperature.
2. Check that all items listed under the topic "PRE-CONDITIONING" (previously mentioned) are in good order.
3. Turn ignition switch "OFF" and wait at least 10 seconds.
4. Start the engine and let it idle for at least 30 seconds.
5. Select "IDLE AIR VOL LEARN" in "ACTIVE TEST" mode.
6. Touch "START' and wait 20 seconds.
7. Make sure that "CMPLT" is displayed on CONSULT-II screen. If "INCMP" is displayed, "Idle Air Volume Learning" will not be carried out successfully. In this case, find the cause of the problem by referring to the NOTE below.
8. Rev up the engine two or three times. Make sure that idle speed and ignition timing are within specifications.
ITEM SPECIFICATION
Idle speed M/T: 625 ± 50 rpm
A/T: 700 ± 50 rpm (in "P" or "N" position)
Ignition timing M/T: 15° ± 2° BTDC
A/T: 15° ± 2° BTDC (in "P" or "N" position)
Without CONSULT-II
5. Disconnect throttle position sensor harness connector (brown), then reconnect it within 5 seconds.
6. Wait 20 seconds.
7. Make sure that idle speed is within specifications. If not, the result will be incomplete. In this case, find the cause of the problem by referring to the NOTE below.
ITEM SPECIFICATION
NOTE:
If idle air volume learning cannot be performed successfully,
proceed as follows:
1. Check that throttle valve is fully closed.
2. Check that downstream of throttle valve is free from air leakage.
3. Adjust closed throttle position switch and reset memory. (Refer to Basic Inspection.)
4. When the above three items check out OK, engine component parts and their installation condition are questionable. Check and eliminate the cause of the problem.
5. If any of the following conditions occur after the engine has started, eliminate the cause of the problem and perform "Idle air volume learning" all over again:
- Engine stalls.
- Erroneous idle.
- Blown fuses related to the IACV-AAC valve system.
I hope this is helpful. Let me know if you have other questions.
Oct 12, 2018 at 10:45 AM
TONIO SELLERS
  • 7 POSTS
Well, I checked the valve and it looks fine. I cleaned the throttle body and still having problems. So this up and down rpm's are happening when I press the clutch in. And it happens when I cruise in neutral or at a stop. And it seems the car wants to accelerate on its own. Seems as if the the throttle is engaged at all times. I have no clue. This morning it was hard to start. Kept stalling until engine was warm and then the rpm's started jumping.
Oct 16, 2018 at 1:22 AM
  • 110,248 POSTS
Welcome back. Has the check engine light come on? If it has, have you scanned the computer to determine if there are trouble codes?
Next, have you checked for engine vacuum leaks?
Let me know,
Oct 16, 2018 at 10:15 AM
TONIO SELLERS
  • 7 POSTS
Crazy thing. After the problems it had starting and staying crank. Around 3:00 pm yesterday I started it and it seems to be working smooth. I guess the throttle body cleaner had to work its way through or something because I drove it for a couple hours and it has not idled high or anything. The rpm's are staying under 1,000 and no problems when I press the clutch in to neutral or when I am at a stop light. It runs like it should now. I do not know. So maybe my throttle body was just very clogged or dirty. Hopefully it continues to work right.
Oct 17, 2018 at 7:14 PM
  • 110,248 POSTS
Welcome back.
That is good news. You are right, maybe the cleaner finally hit the right spot so to say. Regardless, let me know if you need anything else.
Take care and have a good weekend (it is nearly Friday).
Oct 18, 2018 at 9:43 AM
TONIO SELLERS
  • 7 POSTS
Hey again. So after I thought I had the problem fixed the car now stalls if I take my feet off the gas. As soon as I press the clutch to come to stop, the rpm's drop and car shuts off. I do not know what that is. Do you have any idea what it can be? Thanks. Happens when car is cold or warm.
Nov 5, 2018 at 10:49 PM
TONIO SELLERS
  • 7 POSTS
Here is a video.
Nov 6, 2018 at 7:27 AM
TONIO SELLERS
  • 7 POSTS
https://www.2carpros.com/files/temp/7318132128.mov
Nov 6, 2018 at 7:29 AM
  • 110,248 POSTS
Welcome back.
Has the check engine light come on? Also, check the wiring at the IACV. Wiggle the connector with the engine running to see if it changes anything. It is acting like the IACV is bad.
Nov 6, 2018 at 9:50 AM
TONIO SELLERS
  • 7 POSTS
Thanks for replying. But no engine light has come on at all. So this morning I decided to clean the air intake and the MAF sensor. And also sprayed the throttle body again. And the video I posted shows what happened after that. The car stalling went away but the up and down revving started again. I have no idea what it is.
Nov 6, 2018 at 10:11 AM
  • 110,248 POSTS
Interesting. I still feel it has something to do with the IACV. Try moving the harness around and wires to see if it changes. Also, remove it and inspect for debris/carbon.
Nov 6, 2018 at 10:53 AM
