idling only when stop on D mode or using power window
45,000 MILES • 3 CYL • 2WD • AUTOMATIC
MALAKJI
sir, My car has a 1.0 engine. all the things is okay it has great pick every thing is perfect on running, but when i stop on signal on D mode then its start idling or i use power window than it still idling. i do all the tuning, plug change, filter change, but problem still there. tell me the best solution?
Oct 15, 2016 at 4:45 AM
  • 55,770 POSTS
I would start by checking for engine codes and vacuum leaks, here are two guides that will help you
and
Please let us know what you find so it will help others.
Best, Ken
Oct 17, 2016 at 12:09 PM
MALAKJI
there is no engine check light as well as blinking...2nd no vaccum leakage
Oct 18, 2016 at 5:25 AM
  • 55,770 POSTS
I am wondering if you have an air intake boot that is torn can you check it for tears please.
Also a video of the problem would be helpful please upload it to Youtube and then post the link.
Oct 18, 2016 at 10:21 AM
MALAKJI
u dont think its a electric throttle body issue or not...
Oct 18, 2016 at 2:34 PM
  • 55,770 POSTS
This would be for the mass air flow sensor. While you are at it cleaning the mass air flow could help as well.
Here is a guide
https://www.2carpros.com/articles/mass-air-flow-service
Oct 19, 2016 at 2:54 AM
MALAKJI
mass air flow and air intake boot both ok but still problem there car vibrate when stop on d mode or parked otherwise fine..
Nov 6, 2016 at 4:07 AM
  • 55,770 POSTS
If the engine is running okay, it sounds like you might have an engine mount problem. If the engine doesn't vibrate in reverse then check the mounts and get back to me please.
Nov 7, 2016 at 12:23 AM
