Idle up goes down whenever the air conditioner is turned on.
Dec 3, 2016 at 1:20 AM
✓Experienced Mechanic
There is an A/C idle l up solenoid on the inlet manifold, check that the vacuum line to the VSV switch in the fire wall is ok and the electric plug is ok, start here, if you have any doubts a mechanic can check this in a few seconds it's very simple.
