Idling and lights
111,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
PUZZLED ONE
When you first start it it idles way up then back down for around four or five minutes and the lights get really bright then dim while it's idling up and down. It does this every time you start the vehicle until it runs a few minutes and then it's fine.
Feb 24, 2019 at 1:32 AM
  • 110,248 POSTS
First, when the vehicle settles and is running properly, are the lights as bright as they are when you first start it and they get bright? I need to know that to determine if there is a power regulator issue. However, you can check it for me using a simple volt meter.
Here is a link that shows how to test an alternator. It is easy to do. You only need a volt meter or multi meter. I will provide directions on using one later in this post.
Now, what I need you to do is simply check voltage at the battery (cold) with the engine off. Have a helper start the engine. Watch the voltage readings you get as the engine idles high and low, at the same time the lights are getting bright and dim.
The bottom line is this. The change in how bright the lights get can be simply the result of an exceptionally low idle (where the alternator doesn't produce enough voltage) to a higher voltage (when it does its job).
Now, if the voltage goes too high, it can have an affect on the idle air control valve, causing the idle speed to increase. We will determine if that is a possibility once I know the results of the alternator test.
You will need to use a volt meter to check this. Here is a link that shows how that is done:
Let me know what you find or if you need help. Additionally, feel free to ask more questions. I would also like to know if the check engine light is on while the engine is running. That can be helpful.
Feb 24, 2019 at 10:08 AM
PUZZLED ONE
I can't get any voltage reading on the battery with the vehicle off or running, but it'll start every time you turn the key.
Feb 26, 2019 at 12:55 AM
  • 110,248 POSTS
Welcome back:
How are you checking the battery voltage? If it starts the engine, it has to have voltage. Are you using a volt meter? Also, where are you testing?
Feb 26, 2019 at 10:00 AM
PUZZLED ONE
With a voltmeter and on the battery terminals.
Feb 26, 2019 at 1:47 PM
  • 110,248 POSTS
If you are not getting a voltage reading, are you sure the tester is good? Honestly, it doesn't make sense for it to start, but the battery not to have voltage.
Feb 27, 2019 at 11:46 AM
PUZZLED ONE
Yea it's good and it makes no sense to me either. I'll check it again this weekend.
Feb 27, 2019 at 1:50 PM
  • 110,248 POSTS
Sounds like a plan. If you are using a multi meter, make sure it is properly set to read DC voltage.
Let me know what you find.
Feb 28, 2019 at 9:32 AM
