Engine will not idle
83,000 MILES • 3.2L • V8 • 2WD • AUTOMATIC
LEANORE HAYES
  • 16 POSTS
The car starts fine but won't idle. I can drive it as long as keep the RPM's on 1. It was running great and all of a sudden it quit idling.
Jul 19, 2020 at 2:49 PM
Good morning,
This could be the result of a dirty throttle body that has carbon build up.
https://www.2carpros.com/articles/stall-at-idle
Are there any codes in the system? Is the check engine light on? You can have a parts store read the codes for you for free. Once you know the codes, let me know so I can help narrow the area of failure.
Jul 19, 2020 at 9:21 PM
LEANORE HAYES
  • 16 POSTS
No engine light on no codes on. Yesterday when I first started the car it was fine I needed to lock the house so I turned it off when I came back about 2 minutes later and started the car again is when the idle problem started.
Jul 20, 2020 at 1:39 AM
Okay, I would try cleaning the throttle body as I suggested to see if it is any better.
Jul 20, 2020 at 1:58 AM
LEANORE HAYES
  • 16 POSTS
Thank you. I will let you know if it works or not.
Jul 20, 2020 at 2:31 AM
LEANORE HAYES
  • 16 POSTS
I went out this morning and started the car and it is running great again, didn't have to do anything very mysterious.
Jul 21, 2020 at 7:21 AM
I understand. The issue will return as nothing has been done for the issue.
I would still clean the throttle body very well.
Jul 21, 2020 at 7:23 AM
LEANORE HAYES
  • 16 POSTS
Okay, thanks again.
Jul 21, 2020 at 10:03 AM
