Idling
152,654 MILES • 1.3L • V12 • 2WD • MANUAL
ETTAS
Car does not want to idle and when i keep the revs high it idles, but when i leave the revs and it is going lower it quits running. I also replaced the fuel pump and the carburetor is serviced. I thought it was the carburetor or the fuel pump. It is still not idling.
Dec 28, 2018 at 9:17 PM
  • 110,251 POSTS
Most often, what you described is caused by an engine vacuum leak. I have to be honest, this model wasn't offered in the US, so I have no technical information specific to it. What size engine is it? You mention it has a carburetor. Are you sure it isn't fuel injected?
Regardless, here is a link that discusses how to check for engine vacuum leaks. If in fact it has a carburetor, let me know. Also, if it does, there should be a curb idle speed adjuster on or near the throttle.
Here is the link I mentioned. Let me know if it helps.
Dec 30, 2018 at 5:41 AM
