Idling problem
17,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BECKY MURO
Idle is high when start and then it starts going up-and-down fluctuating. I changed the throttle sensor, spark plugs and wires and still continues to do it.
Aug 2, 2018 at 4:26 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
It sounds like you may be having a problem with the idle air control valve. On your car it is located next to the throttle body. I have attached a link showing how to replace. Hope this helps and feel free to ask any further questions if needed. Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Aug 2, 2018 at 9:04 AM
