It starts and idles, but when you give it gas won't go above 1500 RPM. Things I've done, checked fuel pumps, both work, airflow meter also fine, relays fine, plugscap, rotar all fine, catalytic converter not plugged, crank shaft position sensor replaced,
Feb 22, 2016 at 9:38 AM
