Idles will not rev past 1,100 RPMs
257,098 MILES • 5.2L • V8
MOTORCAR222
Did tune up and new IAC and bank 1 sensor 1. Truck starts and idles fine but will not rev up past 1,100 RPMs. Today I tested with vacuum gauge, and it stayed steady at 11. Book says valve timing. It seems to me to be either a vacuum leak or timing. Did a TDC and rotor pointing a #1 on cap.
Mar 16, 2022 at 12:27 PM
  • 110,244 POSTS
The vacuum is low. I would expect it to be around 15 to 18 inches of vacuum at idle. Start by checking for leaks.
Here is a link that explains how to do it. Also, if you find no leaks, let me know if you checked engine compression.
Let me know what you find.
Mar 17, 2022 at 8:20 AM
