Idles rough when gas pedal is pushed and it shuts off
1989 CHEVROLET CAVALIER
200,000 MILES • 2.8L • 6 CYL • 2WD • MANUAL
OHKNOWU812
Replaced fuel lines, fuel filter, fuel pump. Still same thing rough idle and when pedal is pushed it shuts off instantly. Got a code 22 TPS and code 33 MAP. Replaced the throttle pressure sensor. Checked for error codes again . Still had code 33 MAP and now code 44 appears . Replaced map sensor and code 44 disappears. But then get code 33 showing again along with code 34. Car still runs bad like it is starving for gas, but when pedal is pushed it shuts off.
Feb 20, 2018 at 1:12 PM
  • 55,224 POSTS
It sounds like the engine has jumped time we can confirm the issue with a compression test. Here is a guide to help us find out whats wrong:
Cheers, Ken
Feb 22, 2018 at 4:21 AM
