idles rough hesitates jerks around 60 km an hr untill u bring up rpms
190,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BOOTY
truck runs rough .. engine light is now on.. computer says cylin 3 and 4 misfires .. replaced egnition coils on 3 and 4 already .. also put new plugs in 2 months ago .. any more sugg thanks
Sep 27, 2014 at 9:22 AM
  • 110,246 POSTS
Have you replaced the two plugs with the new coils? Is the same code turning back on? Have you checked for vacuum leaks? These vehicles are known for a vacuum developing in a hose behind the throttle body that has a 90 degree bend in it. They dry rot and leak. Also, have you checked fuel pump pressure?
Sep 27, 2014 at 11:03 AM
