Idles high while moving only, occasionally sputters & stalls
139,000 MILES • 1.9L • 4 CYL • 2WD • MANUAL
RINBOTHA
Some background: car has not been well cared for. Oil changes at 10,000miles, no tune ups, stuff like that. While pulling into my driveway one day 3-4 months ago, the car began to sputter down around 100rpm's or so. This has happened numerous times, and the quick fix has always been to floor it -in neutral- up to 4000 or 5000rpm and then let it settle. Usually back to normal. This time, I decided to let it just keep sputtering and wait and see what happens. After 20seconds or so, it corrected itself, then promptly rose to 4200/4300rpm for about 30-40seconds. I let it settle back to normal idle, then shut it off and went in my house. Since then every time I drive it, it revs itself up to 2000rpm the moment the car begins to move, even I neutral or in gear, but with the clutch depressed, and it won't drop to normal idle until 3-4 seconds after the car has come to a complete stop. Also, I've never had to do any work on the clutch or transmission. Still the original clutch & clutch fluid. Still the original fuel filter too. No service engine soon light either.
Jun 20, 2014 at 3:07 AM
SATURNTECH9
  • 30,869 POSTS
The fuel filter should be changed right away there supposed to be changed every 30,000 miles on that car and by then there pretty clogged up by that time. Also I would see if the pcv hose is colasped or has a hole in it.Also have you ever changed the coolant temp sensor the bottom one?
Jun 20, 2014 at 1:59 PM
