Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercury
Marquis
Engine
Symptoms
Idle High
Idles high when put in park only
1992 MERCURY MARQUIS
95,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
TRACEY MCMORRAN
MEMBER
Idle okay in gear. What is causing this?
Jan 3, 2019 at 3:27 AM
DANNY L
Experienced Mechanic
Hello, I'm Danny.
It sounds like you might be having an issue with the idle air control valve.Here is a tutorial showing what is involved:
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Hope this helps and thanks for using 2CarPros.
Danny-
Jan 3, 2019 at 10:51 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
