I have read the other questions related to mine but still don't know what to do. The car started stalling when i came to a quick start so after i Googled it i replaced the IAC and it fixed that issue. Now the car idles very high when you start it up but will back down to a normal idle after a few seconds. It will then start idling high while driving and when you come a stop it will remain at a very high idle until i put it in neutral. Once in neutral it will idle back down so after some research i replaced the TPS and i still have the same issue even after doing a calibration to reset the computer. I have replaced the PCV valve and both hoses. Not sure what's next. I do get a P1506 code to clean the IAC but i just replaced 2 months ago. What's next?
Sep 26, 2020 at 9:16 AM
