Idles high
150,000 MILES • 3.0L • 6 CYL • AUTOMATIC
ITS2LATE2STOP
I cleaned the throttle body and now my car idles high?
Nov 12, 2020 at 7:05 PM
You selected an SL2 with a 3.0L. Did you mean an LS2 with a 3.0L?
I suspect you may have damaged the throttle body or position sensor. Take a look at this attachment where it says to use a specific cleaner and not one that contains methyl ethyl ketone as it can damage it.
I attached the learn process that you can try to see if you can relearn the idle. Also, you may have a DTC and if you do, I attached the info for that.
Nov 13, 2020 at 1:17 AM
