Idles hard, stalls
110,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
REBMREYNOLDS
I have the error codes of:
P0015, P1339, P0300, P0301, P0303, P0302, P0304.
My question is:
Can a faulty camshaft sensor cause the cylinder misfires? I understand P0015 and P1339 are related, but what about the cylinders?
I am at my wits in with the car and if replacing the camshaft sensor will resolve the misfires that would be great. My car is fifty miles from my mechanic and I do not have the money for a tow that distance, but I can afford the camshaft sensor.
Aug 23, 2017 at 4:19 AM
STEVE W.
  • 15,411 POSTS
Yes a bad cam sensor could cause misfires. P1339 is a circuit related code, check the wiring at and to the cam sensor. Corrosion or damage will set that code as well as a bad sensor.
Aug 23, 2017 at 6:18 AM
REBMREYNOLDS
Fantastic! I will check it out for obvious wiring issues and then replace it if need be. Thanks for the information and for getting back to me so quickly!
Aug 23, 2017 at 6:32 AM
