Rough idle
90,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
SKINNEROB45
When the car is a normal operating temperature and I'm idling in traffic the car idles rough, the organge engine light begins to flash, once the light goes back solid and I begin to move again the car sounds and drives rough. Turn it off and back on again and seems to run smooth until idling begins again. Tried replacing coil pack and plug leads but still the problem persists. Please help
Jan 30, 2016 at 2:24 AM
WRENCHTECH
  • 20,760 POSTS
You have a severe misfire. You need to have the codes read and they will help you pinpoint where it is happening.
Jan 30, 2016 at 3:18 AM
SKINNEROB45
Any idea of repair cost?
Jan 30, 2016 at 3:50 AM
WRENCHTECH
  • 20,760 POSTS
You don't even know what the problem is yet, so ................... no
Jan 30, 2016 at 3:58 AM
SKINNEROB45
Ok well, a list of possible problems and general costs would be helpful.
Jan 30, 2016 at 4:03 AM
WRENCHTECH
  • 20,760 POSTS
Various ignition possibilities, fuel injection possibilities. mechanical valve possibilities ranging from $100 to $5000. Now, maybe you should find out what the problem is.
Jan 30, 2016 at 4:25 AM
