Idles, but shuts off when transmission is shifted into gear?
1993 CHEVROLET S-10
118,000 MILES • 4.3L • 4 CYL • 2WD • AUTOMATIC
LAURAREARDEN21
The vehicle listed above is a Blazer with a Vortex 4.3.
She cranks and idles just fine but when you put her in gear and press the gas, shuts off. Like she's being choked for fuel. Everything fuel-wise has been replaced. Help Please.
Oct 13, 2022 at 12:56 PM
  • 110,244 POSTS
Have you checked to make sure there are no engine vacuum leaks? Also, have you checked for diagnostic trouble codes?
This vehicle has an OBD1 system that doesn't require a scan tool to retrieve codes. Here is a link that explains how it is done. All you will need is a short jumper wire or even a paper clip.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know what you find as far as codes. If you haven't checked for vacuum leaks, here is a link that explains how that is done.
Oct 13, 2022 at 2:31 PM
LAURAREARDEN21
I will have that looked at first thing this morning. Thank you for the help and links. Whether it works or not, I will let you know.
Oct 17, 2022 at 1:10 AM
  • 110,244 POSTS
Thanks for the update. I look forward to hearing what is found. I'm interested in knowing.
Oct 17, 2022 at 10:38 AM
LAURAREARDEN21
So, I got my truck home and finally got to see and hear it for myself and you were right. She has a couple vacuum leaks but her wiring is a complete disaster too. And thanks for the links to the scans link too. I'll be returning to fixing her this morning since the storm slacked off.
Oct 25, 2022 at 7:04 PM
  • 110,244 POSTS
Sounds good. Let me know what you find or if I can help in any way.
Oct 26, 2022 at 10:23 AM
