Cranks no spark to the engine
140,000 MILES • 1.8L • 4 CYL • 4WD • AUTOMATIC
ROBCOLEMAN333
Changed serpentine belt and noticed idler pulley twisted and partially intended in plastic cover which i think is the timing cover. Car cranks over but no spark to engine.
Feb 14, 2021 at 7:04 AM
  • 110,248 POSTS
Is it possible for you to take a pic and upload it for me to see? Also, how badly did the pulley indent the plastic? The idea that it twisted doesn't make sense because it shouldn't be mounted on plastic. Also, did it run before this happened?
Here is a link that explains the most common causes of a crank no start:
If possible, upload a pic of the issue so I can see it. Also, let me know if you have other questions.
Take care and God Bless,
Feb 14, 2021 at 9:59 AM
