Replaced the idler pulley or tensioner and the drive belt and now the engine will not start
1996 SAAB 900
135,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
RHONDA PARRENT-SPENCER
The idler pulley or tensioner broke, so it started shredding the drive belt. I replaced both and now the engine wont start.
Sep 30, 2016 at 7:41 AM
  • 55,402 POSTS
Hi RHONDA,
It sounds like you may have an accessory that has locked up, can you remove the belt and see if the engine starts?
Please let us know what you find so it will help others.
Best, Ken
Oct 4, 2016 at 3:32 AM
It ended up be the ignition switch, which is hard to find but I've located..Thank you.
Oct 4, 2016 at 5:58 AM
  • 55,402 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Oct 4, 2016 at 7:40 AM
