I am replacing the idler arm on my vehicle. And I need to know what the torque specs for the bracket to frame and the arm to the bracket.
Feb 24, 2019 at 9:14 PM
SCGRANTURISMO
✓Experienced Mechanic
The information you requested is in the diagrams down below. I hope this helps.
Thanks,
Alex
2CarPros
Images (Click to enlarge)
Feb 25, 2019 at 7:05 AM
CONRADISH006
MEMBER
Are the mounting bracket to frame specs in there?
Feb 25, 2019 at 9:29 AM
SCGRANTURISMO
Hello again,
I'm sorry about that. I thought I had included that in my prior answer to you. I have the entire front suspension torque values listed in the diagrams below for you. I hope this helps.
Thanks,
Alex
2CarPros
Feb 25, 2019 at 6:28 PM
CONRADISH006
MEMBER
So if I am reading those pages correctly the idler arm gets torqued to the bracket to 111 FT-LB. And the bracket gets torqued to the frame to 71 FT-LB. And the idler arm gets torqued to the intermediate shaft to 47 FT-LB.
Feb 25, 2019 at 9:03 PM
CONRADISH006
MEMBER
I forgot to say that my van is a 3500. And 9600 lb GVWR.
Feb 25, 2019 at 9:08 PM
SCGRANTURISMO
Hello again,
The torque specs are the same for the 2500 and 3500.
