Idle weird
58,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
JARRETT.MCGINNIS
Whenever I’m stopped at a stop light or sign it drops rpm's randomly and shakes really bad some worse then others. it also does the same thing when I put my foot on the brake to go from park to drive or reverse. It does it really bad when I drive for awhile and park it and leave it running it will drop rpm's and shake sometimes it drops so much the shake gets worse and feels like the car is going to quit running.
Jan 16, 2019 at 1:58 PM
SCGRANTURISMO
  • 4,897 POSTS
Hi Jarrett, my name is Alex and I will be helping you with your problem today. I have seen the throttle bores get dirty once causes a rough idle I have also seen a MAF sensor cause this. We should run the codes to sewe what comes up.
Jan 16, 2019 at 7:08 PM
  • 55,710 POSTS
If i could sneak my opinion in, this sounds like it can be a vacuum lean or the spark plugs need to be replaced. Here are two guides that can help with the problem:
and
https://www.2carpros.com/articles/stall-at-idle
Please let us know what you find. Cheers, Ken
Jan 21, 2019 at 9:40 AM
