Idle until it stalls
200,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
GFDOOIT
  • 5 POSTS
My wagon, had a bad catalytic converter, we removed it. I put a temporary pipe to test it when driving. It now has power and shifts well. but when idling it starts to gurgle and nearly shuts off. sometimes you will hear a click and it will idle smooth for a little while then slowly begin to start gurgling down until it shuts off.
Aug 23, 2017 at 3:14 AM
CJ MEDEVAC
  • 11,000 POSTS
See "my" first answer in this link. There are three pictures at the end of it.
https://www.2carpros.com/questions/2005-ford-escape-rough-idle-at-low-rpm
I would try the "love tap" while it is beginning to shut off, this might verify the issue (or it may not affect it at all, but still do not rule it out as a possibility).
Keep us posted.
The Medic
Aug 23, 2017 at 8:39 AM
GFDOOIT
  • 5 POSTS
I did change the idle valve and no change. I did put a new Cat Converter it runs great on HWY more power and better MPG. It will idle fine for a few minutes then it will start to droop slowly until it stalls. It will start again fine then do the same thing after a few minutes. I can hear the gas spraying like someone squeezing a spray bottle and it runs accordingly.
Sep 6, 2017 at 11:52 PM
  • 55,732 POSTS
This sounds like a MAF sensor problem or a vacuum leak. If the hot wire becomes contaminated it will misread but not enough to cause a trouble code just make the engine run lean and stall. The same with a vacuum leak.
Here are a couple guides that should help us.
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
and
Please let us know what you find.
Cheers, Ken
Sep 8, 2017 at 3:26 AM
