Idle surge and sticky revs
217,000 MILES • 2.6L • 4 CYL • 4WD • MANUAL
RIPPLE2010
Okay, so my Mazda Bravo has been a small project i have been working on as my first car, and since we have had it it has had a small idle problem. when randomly the revs will drift up to around 1,500 then drop down again, as well as it has what i would describe as a sticky rev, so the revs don't go down as soon as my foot is on the pedal, they stay up for a bit then go down. work we have done on the car so far has been,
a head replacement, new radiator, thermostat, water pump and a new camshaft,
from my research i think it could either be the fuel filter or a vacuum leak. but i need some more mechanically minded people to help identify the issue.
May 31, 2020 at 11:51 AM
  • 55,746 POSTS
Yes, a vacuum leak can cause this issue which is what I as thinking. this guide will help us confirm the issue:
and
https://www.2carpros.com/articles/stall-at-idle
Jun 1, 2020 at 5:27 AM
