idle speed
270,000 MILES • V8 • RWD • AUTOMATIC
SALTWATERNUT
idle speed stays at 1000rpm brakes not much power
Dec 27, 2015 at 6:47 AM
  • 31,937 POSTS
If the brake pedal is high and hard you bay have a vacuum leak at the booster, this will also effect the engine idle, have the booster checked or you can do it quickly by pumping the brake pedal with engine off till the pedal is very hard, hold pedal down and start engine, brake pedal should pull down with pressure applied, if not the booster is faulty or you have a vacuum leak in the booster supply line.
Dec 27, 2015 at 6:54 AM
