Idle speed
253,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
COREY H JENKINS
  • 80 POSTS
Finally got SUV back in one piece and no check engine light.
When you crank it, it idles up to 2000 rpm for six seconds and then levels out at 900 rpm.
When you put it in gear it idles up to 1100 rpm for three seconds and then levels out at 700 rpm.
After that when you go from park to drive, it goes from 900 in park to 700 in drive without the rev up.
But when you cut truck off and restart, it does it all over again.
Is this normal or do i still have a problem?
Jun 26, 2017 at 7:16 AM
  • 55,797 POSTS
This sounds like you have a vacuum leak, here is a guide to help you check for it to confirm.
Please let us know what you find.
Cheers, Ken
Jun 28, 2017 at 11:21 AM
COREY H JENKINS
  • 80 POSTS
Thanks found vacuum leak it's running fine now.
What is it supposed to idle at in park and in drive?
Jun 29, 2017 at 8:02 AM
  • 55,797 POSTS
Nice work, we are here to help, please use 2CarPros anytime. Where was the leak? It should relearn and end up at about 700 RPM
Cheers, Ken
Jun 30, 2017 at 3:27 AM
COREY H JENKINS
  • 80 POSTS
Is that 700 rpms in drive or park?
I get 2 different readings. 900 in park and 700 in drive
Jun 30, 2017 at 3:40 AM
  • 55,797 POSTS
Yep, that sounds about right.
Jun 30, 2017 at 4:27 AM
