Finally got SUV back in one piece and no check engine light.
When you crank it, it idles up to 2000 rpm for six seconds and then levels out at 900 rpm.
When you put it in gear it idles up to 1100 rpm for three seconds and then levels out at 700 rpm.
After that when you go from park to drive, it goes from 900 in park to 700 in drive without the rev up.
But when you cut truck off and restart, it does it all over again.
Is this normal or do i still have a problem?
Jun 26, 2017 at 7:16 AM
