1996 Chevy Tahoe ignition miss
MIKE317
  • 1996 CHEVROLET TAHOE
Engine Performance problem
1996 Chevy Tahoe V8 Four Wheel Drive Automatic 170k miles
1996 tahoe 5.7 I have replaced fuel pump, all filters, complete tune up wires, plugs, cap, rotor, new batt also, and it still has miss especialy under a load. No check engine light and no codes. Is it possible the ignition module is cutting out? Please help.
Wednesday, September 1st, 2010 AT 8:51 PM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
Thursday, September 2nd, 2010 AT 9:12 AM
