stalls at idle
2001 KIA SPORTAGE
208,000 MILES
GLAWRENCE1957
I need to raise the idle speed on my kia sportage. Where is the idle screw on this car? The car dies every time I stop at a light or slow down to go over speed bumps or turn. The car is idling at pretty slowly so I figure I need to adjust the idle speed. I was told it should be idling at 1 on the tachometer. I have added 1 can of seafoam to the gas to clean out the jets and filters so I am pretty confident it is not gunk in the jets. I have tried to find a free manual on-line but so far I haven't had much luck.
May 15, 2013 at 1:19 PM
CARADIODOC
  • 34,379 POSTS
Fuel injected cars don't have idle speed adjustment screws. The Engine Computer controls idle speed through the idle air control valve. That is a passage around the throttle blade. On many cars the computer will lose its memory if the battery is disconnected or run dead and will have to relearn "minimum throttle" before it will know when it has to be in control of idle speed. Until then you also will not get the nice idle flare-up to 1500 rpm when you start the engine, and it may be hard to start unless you hold the gas pedal down 1/4".
Some engines are also prone to that air passage becoming plugged with carbon. The injectors will spray more fuel but you won't get the needed air to go with it.
Not all cars need to do something special to relearn minimum throttle. The only ones I know how to do are Chryslers and those are simple. You need to drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals. You may need to find out your procedure from a Kia mechanic. You can try calling the dealership but often the guys behind the desk don't know the procedure.
Try decoking (cleaning) the throttle bore, here is a guide on how to do it, it will help
May 15, 2013 at 2:32 PM
