Idle run fluctuation and after 2-3 times cranking the engine will be started?
170,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
PETROYADA
  • 66 POSTS
Some measures were taken to rectify the Idel run fluctuation problem as below:
1)The Mass Sensor was replaced.
2) The Throttle Position Sensor was replaced.
3) The Idle Run Sensor was replaced.
Below measures were taken to rectify the 2-3 times cracking problem.
-The fuel pump was replaced.
Sep 1, 2023 at 6:10 PM
