Idle rough when stopped at traffic light or stop sign
2003 VOLKSWAGEN PASSAT
130,000 MILES
SCOTTRJR-23321
Tread Quarters did diagnostic.-Replace line vacuum hose, next day return car w/same problem, install a factory part (unknown), p/u car & return within 2 hours same problem. Was told to go to dealers. Not fair, they got paid, still got the idling & check eng. Light back on. We install 4 coil pack & wires prior to,..but Rough idle & check eng light continues. Help!!
Sep 23, 2013 at 1:45 PM
SATURNTECH9
  • 30,869 POSTS
Which engine do you have ?Also what are the exact code numbers you have not code descriptions?
Sep 23, 2013 at 1:51 PM
EXOVCDS
  • 1,883 POSTS
Replace the PCV check valve.
Thomas
Sep 24, 2013 at 10:03 AM
SATURNTECH9
  • 30,869 POSTS
That's a good one Thomas I had another user with a similar problem with.a pcv leaking vacuum causing issues.They supposedly make a Aftermarket metal one.
Sep 24, 2013 at 12:30 PM
