Traction control light, check engine light turned on and misfire code
200,000 MILES • 4 CYL • AUTOMATIC
TRACEY LACEY
  • 5 POSTS
I went off the road and now traction control light, check engine light turned on, and it's throwing misfire cylinder 3 code.
Dec 8, 2021 at 5:17 AM
  • 110,248 POSTS
Often times when the traction control turns on, it is related to a wheel speed sensor. Were there any codes other than the misfire? When you scanned the computer, were you able to scan the can-bus? CAN stands for controller area network. Basically, all the computers/modules are tied together via a few wires. This type of scan will retrieve codes regardless of the one storing them.
Here is a link that explains how it's done:
Let me know if this has been done, if there are any other codes, and if the ABS light is on.
Dec 8, 2021 at 12:36 PM
TRACEY LACEY
  • 5 POSTS
ABS light is on solid, check engine light traction control is on. cleared everything changed the spark plug in cylinder three where it said misfire drove it and by time I went around the block it was doing it again and only showing misfire in cylinder three. only code it has.
Dec 14, 2021 at 7:14 AM
TRACEY LACEY
  • 5 POSTS
No other scan has been done. I'm going to click the link and see how.
Dec 14, 2021 at 7:15 AM
  • 110,248 POSTS
Hi Tracy, let me know what you find.
Dec 14, 2021 at 9:32 AM
TRACEY LACEY
  • 5 POSTS
I really can't afford to buy the scanner and fix the car.
Dec 15, 2021 at 12:42 AM
TRACEY LACEY
  • 5 POSTS
My son who lives out of state said the obd2 was ABS also if that helps it still only throws misfire in cylinder 3.
Dec 15, 2021 at 1:11 AM
  • 110,248 POSTS
Hi, Tracy,
OBD stands for On-Board Diagnostics. It refers to the automotive electronic system that provides vehicle diagnostic information. The ABS stands for Anti-Lock Brakes. They are two separate systems, but diagnostic codes from the ABS can be retrieved using the OBD. (If that makes sense LOL).
So, the two things, the cylinder three misfire and the ABS are not likely related.
I want you to try something. The misfire could be the result of a faulty ignition coil. So, switch the cylinder 3 coil with cylinder 2. See pic 1 below. I highlighted the numbers 2 and 3 coils. If there is a problem with the number 3 coil, the misfire will move with it to cyl 2. You will need to have it scanned to confirm if it moved or not, but most parts stores will do it free of charge.
All you will need to do is disconnect the electrical connector at the two coils and then there is one bolt holding each in place. Remove the bolt and gently (while twisting back and forth) pull straight up on the coil to remove it. Install is the reverse.
Let's focus on one thing at a time. Once we get this issue resolved, we'll move on to the ABS.
Let me know what you find, if you have questions, or if I can help in any way.
See pic below.
Dec 15, 2021 at 9:57 AM
